Looked at this one this morning and am baffled slightly as to what the problem is.
When you press the “auto light” button the lights for the water dispenser, ice cubes, auto light and the dispenser lamp all flash in time with each other??
Also when you select water on the control panel and put a glass against the actuator pad the motor for the icemaker and the dispenser light flash with the water coming out in spurts at the same time the lights flash.
Is this a control board problem??
John
