Home › Forums › Public Support Forums › Help And Support › Fridge And Freezer Forum › Maytag GS2625GEKB freezer stopped working.
- This topic has 8 replies, 2 voices, and was last updated 14 years, 9 months ago by
louisg.
June 22, 2011 at 5:34 pm #63537
louisg
ParticipantHi,
I have a Maytag GS2625GEKB Side by side fridge freezer roughly 4 years old, yesterday i noticed it was leaking.
On opening the freezer all items were defrosted and ice was melting.
I have removed the front bottom air vent on outside and hoovered out. As was dusty.
I have removed the outside bottom rear panels and hoovered out. As was dusty, there was no evidence of ice or water here.
I removed Mid/Lower panel at back of freezer and checked. No ice build up and also poured hot water down drain, which wasnt blocked.
I have now turned back on in the hope that it starts working again, as im currently at work till 11pm.
Is there anything else i can try or do before calling a engineer. 😥
June 22, 2011 at 7:38 pm #354063ELDAR59
ParticipantRe: Maytag GS2625GEKB freezer stopped working.
nothing really, except to check that you have power there. this sounds like you need an engineer.
is there a noise from the appliance? does the compressor kick in when you open the fridge door?June 22, 2011 at 8:09 pm #354064louisg
Yes there’s power, the lights are still on inside.
Can’t say I have ever noticed the compresser as it’s such a quiet fridge freezer but I will listen out for it.
June 22, 2011 at 8:37 pm #354065ELDAR59
listen for it in particular when you open the fridge door.
June 22, 2011 at 10:25 pm #354066louisg
I can hear a buzzing sound, when I open door all I can hear is the fan.
June 23, 2011 at 8:12 am #354067ELDAR59
sounds like engineer time.
use the facility on this site to get a company familiar with this make.
where are you in the uk?June 23, 2011 at 2:27 pm #354068louisg
Leicester
June 24, 2011 at 12:40 pm #354069louisg
Had a engineer round he says due to a power surge it’s blown the main motor (compressor) roughly £230 to fix.
I’m just talking to my house insurance to see if they will pay for it?
June 26, 2011 at 7:20 pm #354070ELDAR59
if it’s the compressor then £230 isn’t a bad price at all. a power surge blown it though???
if it’s the pcb, then the part will be about £70 ish, obviously plus labour. -
