Home › Forums › Trade Technical & Spare Parts Forums › Trade Technical Enquiries › Maytag LAT9606GGE Buzz
- This topic has 24 replies, 8 voices, and was last updated 19 years, 1 month ago by
Simmy.
March 10, 2007 at 3:48 pm #206737
dpm
ParticipantYou *sure* you’re on the uf range?
What does it read on the resistance range?
/nips out to car, brings in two different meters…On both of mine, 000= shortcircuit
March 11, 2007 at 7:25 am #206738Simmy
ParticipantRe: Maytag LAT9606GGE Buzz
spanner51 wrote:If you haven’t the correct test instrument to check the capacitor your only choice is trial and error and to try a new one. However a faulty capacitor is not very common. Another possibility is the centrifugal switch sticking. If the switch is faulty it is easily replaced. If the accuator lever is sticking it usually means a new motor.
Graham
I really don’t think its the capacitor because the machine usually works fine after the first time of having to tap the motor. Where can I find the centrifugal switch and the accuator lever? I have looked at the diagrams on the maytag site (http://services.maytag.com/abs/PartsStore.do) and on the wiring diagram I found the centrifugal switch but it looks like its inside the motor.Thanks!
March 11, 2007 at 8:12 am #206739Martin
Participantdpm wrote:On both of mine, 000= shortcircuit
You too huh?
Simmy wrote:and on the wiring diagram I found the centrifugal switch but it looks like its inside the motor
It has to be attached the the motors rotor for it to work, so yes it’s inside the motor. 😉
March 11, 2007 at 10:19 am #206740dpm
ParticipantYes, Martin. 000 on the *capacitance* range indicates a s/c cap…
March 11, 2007 at 7:56 pm #206741lokring
yup the centrifugal switch is part of the motor 😀 part no p 207424 about £200
March 11, 2007 at 9:17 pm #206742WhiteVanMan1
I test capacitors by charging them up with a metrohm. Connect and watch the needle drop back as it charges. It’s a pretty good indicator, and it’s the way we were told to do it when I was at hotpoint.
SteveMarch 12, 2007 at 7:08 am #206743Simmy
Spanner51,
How can I check if the centrifugal switch is the problem? How do I access it? Do you have a link where I can get the switch since maytag doesn’t list it as a separate part?Thanks for the help!
March 13, 2007 at 6:11 pm #206744spanner51
Simmy
The centrifugal switch, or start switch, is screwed on top of the motor. It should click when the button is pushed. A wiring diagram is usually behind the control panel. The switch is available as a seperate item p/n 205131, from JLA 01422824444. If the switch accuator lever is the problem, it usually means a new motor. So, be certain of a faulty switch before you order one, as it is not a cheap part.
GrahamMarch 13, 2007 at 7:09 pm #206745Simmy
spanner51 wrote:Simmy
The centrifugal switch, or start switch, is screwed on top of the motor. It should click when the button is pushed.Sorry for the silly question but do you mean when the motor is supposed to start?
GrahamAny suggestion on how I can check the start switch? Where is the accuator lever I don’t see it in any of the parts lists?
Graham I really appreciate all of you help, thanks!
March 13, 2007 at 7:44 pm #206746roly16
WhiteVanMan1 wrote:I test capacitors by charging them up with a metrohm. Connect and watch the needle drop back as it charges. It’s a pretty good indicator, and it’s the way we were told to do it when I was at hotpoint.
SteveThat’ll check for open or short circuited capacitor but it won’t tell you if the capacitance value has dropped far enough over time to prevent the motor starting. You really need a multimeter with capacitance ranges up to 200uF.
