Maytag LAT9606GGE Buzz
Viewing 15 posts - 1 through 15 (of 25 total)
  • #25619
    Simmy
    After this machine finishes filling the tub it starts buzzing (and sometimes at other points when it needs to start spinning or agitating). For a while it was possible to jerk the machine around and then it would start. The lid switch just needed to be replaced and the jerk start isn’t working. Any ideas what the problem is/could be?
    Simmy
    #206723
    spanner51
    Re: Maytag LAT9606GGE Buzz
    Some of the Maytag machines have capacitors on the motor, check this first. Does it run with the belt off? possible seized gearbox.
    Graham
    #206724
    Simmy
    I checked the capacitor and it seems ok. I haven’t tried removing the belt, but next time it gets stuck I will.
    Thanks for the ideas!
    #206725
    lokring
    siezed or sticking drain pump is another possibility!!
    so next time its buzzin take of the belt and if the motor runs ok then try turning the pump by hand…good luck!
    #206726
    lokring
    if someone says my washer is “buzzin” in my area its a good thing!!
    remember the peter kay sketch about the cinama and screen 3 buzzin 🙂
    #206727
    Simmy
    I took off both of the belts and it still buzzes. If I give the motor a few taps on the side it starts up. Could it still be the capacitor? the capacitor is 65-77 mf and my digital multimeter only reads up to 20 so I have checked it with OHM and it doesn’t read infinity.
    Any other ideas appreciated!
    #206728
    You cannot read the capacitance value with a multimeter Simmy 😉
    #206729
    spanner51
    If you haven’t the correct test instrument to check the capacitor your only choice is trial and error and to try a new one. However a faulty capacitor is not very common. Another possibility is the centrifugal switch sticking. If the switch is faulty it is easily replaced. If the accuator lever is sticking it usually means a new motor.
    Graham
    #206730
    dpm
    You can measure capacitance on the capacitance range of a multimeter so equipped, Martin…
    #206731
    roly16
    Simmy wrote:I took off both of the belts and it still buzzes. If I give the motor a few taps on the side it starts up. Could it still be the capacitor? the capacitor is 65-77 mf and my digital multimeter only reads up to 20 so I have checked it with OHM and it doesn’t read infinity.
    Buy a decent capacitance meter :rotfl:
    #206732
    dpm wrote:You can measure capacitance on the capacitance range of a multimeter so equipped, Martin…
    Then now’s a good opportunity to teach this ‘old dog a new trick’….. 😉
    …I’ve got my meter ready….do please explain how I can test a capacitor?
    #206733
    BobHope
    hi martin
    you can buy a multimeter with a capacitance tester built in.
    http://cpc.farnell.com/jsp/endecaSearch … KU=IN00804
    Bob.
    #206734
    BobHope wrote:you can buy a multimeter with a capacitance tester built in.
    Thanks for that Bob but yes I already have the test meter like that but I have never ever figured how the hell you test a capacitor? In fact I’ve got 2 (brand new) capacitors on my desk, a 12.5mf and a 16mf. How can my meter tell me which one is which? I’d love to know….. 😀
    #206735
    dpm
    Martin, you simply plug the cap into the socket on the meter (or apply the probes to it) and wait for the meter to work it’s magic. IIRC, the cap under test is put into an R-C or L-C circuit.
    We’re talking about an actual capacitance range on the selector, not just watching it charge on the Ohms setting…
    #206736
    dpm wrote:IIRC, the cap under test is put into an R-C or L-C circuit.
    Thanks anyway but you’ve lost me there. 😕
    I’ve got a 16mf capacitor, I set it on the 20mf scale and bung the test leads on the cap terminals? ZIPPO !!!!(Digital readout = 000) :rolls: Switching my meter from AC to DC makes no never mind either?
    Try another multimeter says I ?…. 8) Just the same…… 😕 Maybe the batteries are duff? Stick a new set in, no difference….Put meter away and watch the telly instead?…Good idea! 8)
