Maytag MSS20C1114 Ice Cube System
Home Forums Trade Technical & Spare Parts Forums Trade Technical Enquiries Maytag MSS20C1114 Ice Cube System
  • #88119
    jontymox
    Good morning all,
    I’m wondering if someone could shed some light on a problem with the above American style fridge/freezer?
    Essentially, it isn’t functioning correctly, and water is distributed from the unit down into the freezer section.
    I know little about these appliances, and may refer the customer to a specialist, but did say I would try and help.
    Do the symptoms appear to be a faulty unit, and if so, does one renew it? Or perhaps there are certain tests which can be conducted?
    Any help much appreciated.
    jonty
    #437052
    Re: Maytag MSS20C1114 Ice Cube System
    If you have ice forming on the base of the freezer section then it’s probably due to a blocked drain.
    Bryan
