Maytag MWA 09149 WH/1 – error F12
Home Forums Public Support Forums Help And Support Washing Machine Help Forum Maytag MWA 09149 WH/1 – error F12
  • #85019
    tyusaf
    Hi All
    Maytag washing machine, MWA 09149 WH/1 – was in the middle of a wash, stopped with red symbol and flashing F:12 error.
    Washing was wet – removed
    Emptied the water using the bottom drain plug – nothing stuck in there, not a huge amount of water.
    Tried turning off (remove plug) for 15 mins – whenever I try and start any wash, I can hear a few relay clicks, and then immediately after, F:12 error and red symbol again.
    Can’t find this specific error anywhere online or on the forum – does anyone know what this is?
    If it’s fixable – any suggestions for someone in Warwick/CV34?
    #427457
    simon26r
    Re: Maytag MWA 09149 WH/1 – error F12
    HI. F12 is a drain Error code. So pull out the filter and then look in the back and see if you can feel the pump blade. you should be able to flick it round with your finger. if it does not move something is stuck in it.
    If its not stuck you could have coins in the hose or the pumps had it.
    there is a bad video on youtube if you search Maytag F12
    #427458
    tyusaf
    Cool, thanks, will check that out…
