maytag MWA10149WH f22
  • #93172
    char14lew
    I’m going back to this one with test program, error code lists this as a pcb problem.
    checked wiring to door lock,motor- ok. It won’t start a cycle but when I press reset it pumps out and displays E05, nothing listed in fault codes for this?
    Anyone repaired one of these boards?
    cheers Darrell
    #453410
    Re: maytag MWA10149WH f22
    checked the manual which you have access to as well. all error codes start F.
    have not seen them come up with E codes
    the manual shows a way of getting stored error codes. that’s the first thing I would do
    char14lew
    yeah have that info thanks Dave, just wondered if anyone new about the e05 as it’s an unlisted fault or had repaired the board. thanks
