maytag neptune
  • #10798
    stu123
    anyone had any experence with this beauty got suckered into fixing 2 of them on the promise that if the repair was more than 50.00 they would buy new only to then be told they would like them repaired so 1 one no prob broken wire 2nd one no motor action have swapped modules and motor no faults there tried calling maytag for a service manual christ youd have thought i asked for the crown jewels 😆 so any thoughts apreceated 💡
    #142771
    BobHope
    Re: maytag neptune
    Hi Stu123,
    welcome to the site,
    will have a look to see if i have that tech info in the morning, Maytag is a nightmare for tech info. 👿
    Cheers Bob.
    #142772
    Re: maytag neptune
    Perhaps there is a US equivalent of this site that could help? I suppose folk in the States are afraid of giving advice though, in case they get sued. 😉
    #142773
    chezza
    Re: maytag neptune
    these have an ” unbalance ” switch attached to the top weight, and on some of the earlier versions there was a second one fitted to one of the rear struts.
    worth checking these, as there was a tendancy for the switch to break off. also, dont rely on continuity check through the switches if you are testing – better to link out BUT ONLY FOR TESTING PURPOSES….. dont leave the switches linked out.
    another weak point was the pcb in the control panel, fixed to the rear – occasionally you could find dry soldered joint there.
    hope this helps, eddie
    #142774
    Re: maytag neptune
    Check this out:
    http://www.fixitnow.com/
    Pages and pages of Neptune stuff.
    Cheers,
    clivejameson
    Re: maytag neptune
    Penguin45 wrote:Check this out:
    Cheers,
    LMAO!….’Kicking Aplliance Butt All Over The Globe’
    :rotfl:
    #142776
    Re: maytag neptune
    Yup, it’s all quite drole, you’ll even find our own Kiwiwantsworkincanada (andnowgotit) posting on it, but if you look, the info is there.
    Hai!
    bassman
    Re: maytag neptune
    Try This site for Maytag info http://www.repairclinic.com.
    Best of luck Bassman
    #142778
    Re: maytag neptune
    stu123 wrote:anyone had any experence with this beauty got suckered into fixing 2 of them on the promise that if the repair was more than 50.00 they would buy new only to then be told they would like them repaired so 1 one no prob broken wire 2nd one no motor action have swapped modules and motor no faults there tried calling maytag for a service manual christ youd have thought i asked for the crown jewels 😆 so any thoughts apreceated 💡
    £50! 😯 do they know how much these cost? I wouldnt even think of attending one of those for £50 yet alone fixing it.
    #142779
    stu123
    Re: maytag neptune
    thanks for your helpfull suggestions seams door lock unit to blame one to remember
