Maytag not producing ice or water.
Have you been able to check that water is flowing through the filter and to the valve?
If it is then you will need to check the resistance of the valve by unplugging its connectors and testing through these terminals. You will also need to get tested that the valve is getting power on demand but would recommended you do this unless you are a competent person with regards to electrics.
Never test on a live appliance. Always remove the plug.
Sent from Steves
iPhone using Tapatalk
