hi
i’ve got a maytag fridge/freezer model gs2125cew/16 s/n16319731cr
the problem is its not making ice…if i put ice which i have already made in the tray then it will be dispensed out of the dispenser in the door as normal it also dispenses water.
I switched the machine off for about 5 mins then switched it back on with the arm in the off position (at the top), once switched on water was dispensed into the ice maker with the arm rotating for about 1 min then nothing…i was wondering if this was a normal fault found with the ice maker unit or not? if not have you got any ideas what may be causing it?
any info will be a great help cheers
rob
