Home › Forums › Trade Technical & Spare Parts Forums › Trade Technical Enquiries › Maytag TD Mod: MDE5605AES
- This topic has 4 replies, 3 voices, and was last updated 19 years, 8 months ago by
Alanj.
July 26, 2006 at 11:09 am #19442
Alanj
ParticipantHi Guys,
been to this tumble dryer this morning. Customer says it is taking over 3 hrs to go through program before flashing up a time out error. It’s controlled by a PCB,so is it likely to be the PCB or is there a sensor that could be at fault?
Thanks in advance
Alan
July 26, 2006 at 3:01 pm #183113chezza
ParticipantRe: Maytag TD Mod: MDE5605AES
worth checking the ducting etc are all clear, if this is happening on an auto dry setting, also fan etc unrestricted.
July 26, 2006 at 11:13 pm #183114burns
COMMON QUESTIONS AND PROBLEMS
The washing will not dry?
The machine only runs for 20 minutes?
1. Mains power fuse has blown.
2. Overheating, fluff blocking the filter, condenser
unit or fan housing.
3. Overfilling: The display shows “Fault indication,
filling”
4. The machine does not reach the measured
value of 1,8 mV within 15 minutes.
This can be due to:
– Incorrect connection to single phase = too
low heating element power (720 or 600 W)
– Incorrect connection of element to control
unit
– Incorrect connection in element terminal
block
– Humidity sensor not located in fan hous
ing
– Faulty humidity sensor
– Heating element open circuit
5. Drive belt running incorrectly on motor shaft
= too high drum speed > 56 rpm
Overheating protection tripped even though
fluff filter and condenser unit have been
cleaned.
1. Fault in control unit
2. Fluff in internal fan wheel – clean also air ducts
and behind the element.
3. Motor overheating protection tripped.
The machine shows the Maximum program
time fault indication.
The indication means that the machine has been
running for the maximum time (= 3 hours) that
the control unit is allowed.This can have several independent reasons, or a
combination of these.
2. Fluff in the filter, condenser unit or fan hou
sing.
3. Incorrect connection to single phase, 10A
4. External air is restricted or blocked, resulting
in poor condensation
5. High ambient temperature + low heating ele
ment power + low drying temperature resul
ting in poor condensation
6. Low ambient temperature + low heating ele
ment power + low drying temperature so that
it is difficult to get the dampness out of the
clothes .
7. The washing has been spun dry at low speed,
i.e. less than 800 rpm
8. The washing has been taken out before the
program was completed. The machine was
then loaded with a new batch of washing. In
that case the control unit did not have time
to reset itself and the time was added to the
next drying cycle.
9. Damaged humidity sensor, its wiring or con
nections.July 27, 2006 at 7:24 am #183115Alanj
Thanks for the help guys.
Alan
July 27, 2006 at 7:51 am #183116burns
If its lint build up, remove the bottom panel front, you will see a cover with the humidity sensor in (blower wheel) inside – thats common to build up there.
Also check right through the back for linting. -
