Maytag top loader MAT13MNEGW overfilling.
Home Forums Trade Technical & Spare Parts Forums Trade Technical Enquiries Maytag top loader MAT13MNEGW overfilling.
Viewing 1 post (of 1 total)
  • #57609
    aqualectric
    Maytag top loaders X 2. Both are model no:- MAT13MNEGW. Serial nos:- 11428573QW and 11428575QW.
    I have 2 of these machines with the same fault. They both overfill and start to syphon out.
    Removed and cleaned both pressure bottles and checked hoses for holes. All OK. The pressure switches will shut off the water if manually actuated (blow down the pressure switch hose). I can only assume the pressure switches are duff. It requires quite a bit of pressure to shut off the pressure switches.
    But to happen on both machines? Is this a common failure on these? The switch is a metal framed unit and looks bulletproof.
    Anyone had any experience of this problem? Part numbers would be useful. Any information appreciated!!
    Thanks,
    Steve.
