Meile Fridge Freezer displaying F instead of C
Home Forums Public Support Forums Help And Support Fridge And Freezer Forum Meile Fridge Freezer displaying F instead of C
  • #73820
    iant
    I have a 6yr old meile fridge freezer that has a temperature display fault. Instead of displaying the temperature in degrees C it has changed to displaying the temp in degrees F ! Is it possible to change back, if so how? Thanks
    #388903
    don
    Re: Meile Fridge Freezer displaying F instead of C
    Which model number do you have ❓
    Don
    #388904
    iant
    Hi Don
    The model number is KFN 8662 SD
    Ian
    #388905
    don
    Iv’e had a quick look in the instructions but can’t see it in there. It may be that it needs an engineers touch 😉
    Don
    #388906
    iant
    I was hoping an engineer on your forum might know, otherwise it is expensive to call out a Meile engineer. I have checked the cct boards and there are no microswitches on them to change it over so i’m guessing that there must be a switch combination that will do it.
    #388907
    ELDAR59
    hello, what value is it showing?
    are you sure it’s not showing a fault code, ie F2, F4 etc.
    #388908
    iant
    Definitly showing temperature in Fahrenheit. The fridge shows the temp range of +36 to +53 ( equiv C is 2 to 12)and the freezer shows the range +5 to -14 (Equiv deg C is -15 to -25). Perhaps I should just change the markings on the display to F !! and pretend I am living in the past.
