meile g 645 sc plus leaking
Home Forums Public Support Forums Help And Support Dishwasher Help Forum meile g 645 sc plus leaking
Viewing 1 post (of 1 total)
  • #81169
    kboy
    Dear forum,
    my dishwasher has started leaking water from the white plastic circulation housing that sits on top off the large motor directly under the base base..
    There is a purpose made opening in the casing where the water is running down.
    I am assuming that there are seals within the housing that have perished.
    Can you get replacement seals for these and if so where from and how do you remove the motor and housing from the bowl of the dish washer . I have tried pulling but it is reluctant to move. I am assuming that the seal is holding the unit on tight any advice greatly appreciated.
