Meile G641 dishwasher
  • #46116
    maltheviking
    Friend of mine rang me and asked me why the salt light is always on even when she has filled the salt compartment 😕 , anyone any suggestions please?
    #288278
    clayside
    Re: Meile G641 dishwasher
    Not had this fault on this model but it has a float in the salt container, remove salt cap and it is on the right hand side with yellow or green cap
    It could be the float has stuck. If you remove the cap you can get the float out with long nosed pliers, make sure not to drop cap or float into salt. Only other thing I can think is rely on board. Hope this is some help.
    clayside
    #288279
    maltheviking
    Cheers Clayside I will have a look 😉
    #288280
    philfish
    think they also have a reed switch on the side of the container
    hth
    phil
    #288281
    maltheviking
    philfish wrote:think they also have a reed switch on the side of the container
    hth
    phil
    That must mean there’s a magnet on the float
    #288282
    philfish
    Yes it does 😉
    #288283
    clayside
    If the float is removed then the salt light goes out, so that why I thought that if float stuck down then light stays on.
    clayside
