Meile G646SC Plus No drain fault
Home Forums Public Support Forums Help And Support Dishwasher Help Forum Meile G646SC Plus No drain fault
  • #52321
    Robby74
    Hi All
    Have a Meile G646SC dishwasher with a no drain fault, have checked the pump, no blockages, cleared a blokage in the bottom of the matix, when it’s run on the next load the no drain fault returns, also checked the temperature of the circulating pump after 20 minutes, all seemed fine. Any suggestions would be gratefully received
    All the best Rob
    #311337
    Re: Meile G646SC Plus No drain fault
    Does it actually drain the water?
    Robby74
    I’ve now sorted the problem, thanks for the reply. 🙂 Dry joint’s on the PCB.
