MEILE W864
  • #84793
    blokes
    Hi Guys,
    Got a W864 starts as per normal but then goes to Soak/prewash light flashing and anti-crease/finish light on.
    Any help
    Steve
    #426784
    Muv
    Re: MEILE W864
    Is it heating the water?
    blokes
    Re: MEILE W864
    Thanks Martin,
    I don’t think it is getting that far. It takes water in and tries to tumble then cuts off.
    It will do a spin if set separately.
    Steve
    #426786
    Muv
    Re: MEILE W864
    Sounds like a pressure switch problem,try replacing the tubing,or reversing it after checking its not leaking air…if that doesn’t cure it a new switch is required
    M
