Re: MFI freezer – alarm problem
One of two likely problems, either the unit is not getting down to the correct temperature which is causing the alarm to go off, or the thermostat is duff. By pressing the fast freeze all you are doing is connecting the electric up to the motor byepassing the thermostat. This could result in the motor burning out. There are two different thermostats fitted to this appliance, the correct one identification is dependent on the serial number.
