MFI? integrated fridge hinge problem
Home Forums Public Support Forums Help And Support Fridge And Freezer Forum MFI? integrated fridge hinge problem
  • #37457
    ANDY1234567
    Hi I have an integrated fridge and freezer, which looking at previous Posts are MFI units. (AMP 6121/6125). The freezer is fine and in fact the door seal is very strong. However The fridge does not seal properly. The facia door is not quite aligned and on inspection the top hinge appears to have some play in it when compared to the freezer, but I don’t think it’s actually broken. Can you still get these hinges, how easy are they to fit and most importantly is it likely to cure the problem?
    Thanks in Anticipation
    Andy
    #255195
    Re: MFI? integrated fridge hinge problem
    Do the top two hinges HERE look familiar?
    They carry both the door and decor door, so are pretty crucial.
    ANDY1234567
    Hi Penguin 45,
    Yes they do, are they easy to fit?
    Cheers
    Andy
    #255197
    Screwdriver and patience – it’s all got to line up when you finish.
    Most people buy a pair, BTW – if one’s gone, the other won’t be far behind….
    ANDY1234567
    Thanks Penguin45!! Most helpful.
    Not looking forward to the job
    By the sound of it they are prone to failure. the kitchen is only around 3-4 years old. I guess that the freezer is ok as it doesn’t get opened nearly as often
    cheers
    Andy
