Microwave combination oven Sharp R-957
Home Forums Trade Technical & Spare Parts Forums Trade Technical Enquiries Microwave combination oven Sharp R-957
  • #88358
    FlyingBrick
    Microwave part of the appliance blew the internal 8.0 amp fuse inside and checked out the HT cap which was leaking badly, this in turn had cooked the HT transformer so when only half the mains voltage was applied with a variac it started to cook nicely at 10.0amps giving out some 800v negative. Magnetron ok and changed capacitor for a new 1.06 micro farad. Diodes all ok and swopped out just in case
    Now I need a replacement transformer (unit spec 900 W) RTRN-A016URE1 but can only find a RTRN-A018URE0 S/H transformer on eBay but that unit came from a Sharp R-254 (800 W) microwave oven.
    Does anybody now what the power spec is for these Korean HT transformers are and if the RTRN-A018URE0 would supply enough power without frying up for my 900 watt unit?
    Any chaps out there with microwave knowledge on these HT transformers installed in Sharp units?
    FlyingBrick
    #437805
    Re: Microwave combination oven Sharp R-957
    did you manage to sort your transformer ?
    FlyingBrick
    Took a punt on a second hand one on eBay by Green Recycling Ltd.
    Slightly smaller windings for a lower powered Sharp transformer but the filament long lead had been cut right through from the transformer base whilst in transit. (5 kg)
    Hope to wire it up and check the lamination temp whilst on and monitoring the HT voltage. (have a 40KV high voltage probe)
    Many thanks Dave for the email. Hands in pockets on this one?
    Chris Smith
    #437807
    may have one if you get stuck
    transformer is in sharp combi unit rated 900w using i think a 1.16uF cap
    have the rest of the model info in work
    when you say high voltage probe, if it was designed for tv dont use it
    transformer will give out about 2500V AC
