Re: Microwave Installation Height
It does vary I must admit.
Hotpoint are okay unless it’s a side open door model, Neff say you can, but if it’s being installed under a hob then the submerged depth must be considered.
Miele do seem to be the only one’s who say they are not suitable for installation under a worktop. Trouble is if you install it and it develops a fault Miele will simply walk away as the installation has not been carried out in accordance with the instructions. If you require further info then a call to them on 01235 554455 may be the way to go.
HTH 🙂
Don
