Microwave needed
  • #16660
    DynamicalSystem
    Can anyone recommend a new microwave.
    Needs to be
    1000W minimum
    Freestanding
    Easy to use
    No combi/grill/convection stuff – just a microwave
    Must easily cope with a 28cm plate, with 16cm height
    By preference
    Stainless steel
    Flexible on
    Budget – would rather stick below 200, but it’s not a constraint
    commercial/domestic unit
    Primary use
    We will be using it for sterilising baby stuff, heating food from frozen, defrosting, canned soups.
    All suggestions will be gratefully received.
    #170919
    DynamicalSystem
    Re: Microwave needed
    Would I be right in assuming from the lack of response, that either there are none that fit the bill, or that microwaves are such a commodity that it matters little which one I should buy?
    Anyone got any favourites?
    #170920
    I suspect none of us are particularly clued up on commercial stuff – we mainly sort out domestic appliances.
    Anyway, couple of links that might be of interest:
    http://www.peter-stott.co.uk/sharp{e5d1b7155a01ef1f3b9c9968eaba33524ee81600d00d4be2b4d93ac2e58cec2d}20mi … ovens.html
    http://www.ripples.co.uk/
    Hope that helps a little,
    DynamicalSystem
    Many thanks for that.
    I’m not bothered if it’s a commercial or a domestic unit. If there is a domestic unit that you can recommend, then I would love to look at it.
    I thought there may be better value in the commercial world since they are probably geared to higher use, the aesthetics are similar to modern kitchens (stainless, metal buttons etc), and I thought the user interfaces might be more appropriate to the limited functionality I need. That said – I don’t have much of a clue about this stuff.
    #170922
    AMS
    You could try AWI microwaves who have a good range of commercial ovens, although they are trade to trade supplier.
    http://www.awimicrowaves.com/ovens/?PHP … 0d964d43d9
    don
    Samsung produce a reasonably priced commercial microwave oven for light use CM1049 comes with a three year warranty.
    Sharp also have one with a slightly larger cavity which has a one year warranty model R21AT.
    HTH
    Don
