microwave only half heat sharp 1500w/r-22at
Home Forums Trade Technical & Spare Parts Forums Trade Technical Enquiries microwave only half heat sharp 1500w/r-22at
  • #53576
    torxhead
    wondered if anyone had any ideas?
    ive got a sharp commercial microwave, customer complains of only having half the power. model 1500w/r-22at.
    there are two magnetrons and transformers, like two microwaves in one.
    i have disconnected each transformer one at a time and thee doesnt appear to be any less heating power.
    t.i.a.
    #316505
    chezza
    Re: microwave only half heat sharp 1500w/r-22at
    When you say doesnt appear to be any less power, have you tested for power output ?
    try this http://www.gallawa.com/microtech/output.html with one side at a time disconnected , but please make sure you safely discharge capacitors each time and follow sensible safety precautions
    #316506
    LJDomestics
    work on it as if it is two micro’s in one.
    test one side as u would then the other.
    done hundreds of these over the yrs.
    there is one way of testing that power is going to the mags that i used to do but dare not post how on here. lol
    #316507
    torxhead
    thanks to both posts. will give that a go later today
    #316508
    torxhead
    update.
    did the wattage test, strange result.
    both magnetrons are working, but only 3/4 power from both.
    #316509
    torxhead
    any suggestions?
    could it be the circuit board?
    #316510
    torxhead
    power output is only 1000w. both magnetrons are working
  • The topic ‘microwave only half heat sharp 1500w/r-22at’ is closed to new replies.
