Microwave paint
  • #9983
    Furhan
    Does anyone know for sure if ordinary enamel appliance pain can be applied to the inside of a microwave or whether a particular type of paint is required.
    #137647
    Bryan
    Re: Microwave paint
    Normal enamel paint would be a definite NO.
    Connect do a special paint , if you search for TU2.
    Unless it is a small area , this repair is a nightmare as it will soon start peeling again. 🙁
    Best just to rub down the loose paint and leave the metal work exposed.
    As long as metalwork intact then all will be ok. 😉
    Hope this helps
    Bryan
    #137648
    Re: Microwave paint
    If you remember the old “airfix” enamel which I used to paint model aircraft with $0 (oops) years ago. It does a good job.
    Kevin
