Hi Guys
Went to look at this Midea W/M with a E31 error code. Apart from the error two things caught my attention. 1) the door interlock made by EMZ DC6400652D has two connector blocks 1 three wires & the other four wires. What is the other connector for ?. I believe these interlocks are fitted to some Samsung machines. 2) The pressureswitch SPS-L11LS DC 5v. I have 23 ohms between 2 pins & the others are O/C (3 pins in all),this doesn’t change if I blow up the switch. Can anyone enlighten me on this pressureswitch & interlock. Thanks Mack.
