Miele 300 washing machine – Replace bearings or new machine?
Home Forums Public Support Forums Help And Support Washing Machine Help Forum Miele 300 washing machine – Replace bearings or new machine?
  • #80545
    Buuuug
    My drum wanders a lot, spins freely then stops and grinds for a part of the turn then repeats. Its either the bearings or spider so requires removing drum either way.
    I have spent some hours trying to remove it, almost there but, in all honesty, is it worth fixing or should i replace the whole machine? There is a Bosch for £239.
    Thank you
    Nat
    #413277
    Re: Miele 300 washing machine – Replace bearings or new mach
    Buuuug wrote:I have spent some hours trying to remove it, almost there but, in all honesty, is it worth fixing or should i replace the whole machine?
    It is well worth the trouble. 😀
    Buuuug wrote: There is a Bosch for £239.
    Don’t waste your money on low end Bosch, the quality is just as low. 🙁
    #413278
    Buuuug
    If a repair is the common consenus then is there a recommended person based in Kent who would take on the job at this stage?
    #413279
    don
    Hi Nat
    Try our Find an engineer link.
    Don
    #413280
    Buuuug
    Oh, thanks Don.
    I called a number of people during my lunch break and none will touch a Miele as Miele have their own teams.
    Will try the link thanks
