miele 4840/w827
  • #26216
    maltheviking
    Has two model no.s 😕
    Called to this machine because the door would not open. Switched the machine on and presto, the door opened 😕 Set the machine of on a wash prog. machine overfilled and the “check inlet light came on”. and started to drain out.
    I switched to “finish” and opened the door. Now when you close the door and the machine starts to fill immediatly until it overfills again. I cannot access the test sequence also. 😕 I don’t work on these to often, am I missing something basic here?
    😥 M
    #209223
    Re: miele 4840/w827
    Pressure bell on front of tub?
    maltheviking
    Re: miele 4840/w827
    Penguin45 wrote:Pressure bell on front of tub?
    Checked the pressure bell (chamber), all clear Chris 😕
    #209225
    Seamy
    Re: miele 4840/w827
    I’d check for condensation or tracking on control board , i’ve had some with relay contacts shorted by dampness & giving faults like that.
    #209226
    maltheviking
    Re: miele 4840/w827
    Thanks Seamy
    Machine’s next to a massive central heating boiler! Tropical without the humidity 8)
    I will give it a check though.
    Cheers
