Miele Auto W842 Rinse Light Flashing?
Home Forums Trade Technical & Spare Parts Forums Trade Technical Enquiries Miele Auto W842 Rinse Light Flashing?
  • #91477
    laurenceuk
    Customer heard a loud mechanical bang from this machine after which it became faulty. It had just a couple of large towels in it.
    1. When a wash prog is selected it will fill then after a few seconds the rinse light flashes continuously.
    2. If I cancel the program it will empty out ok.
    3. If I select a spin only prog it will do the same as 1 above re rinse flashing after a few seconds.
    I’m assuming it is not detecting any motor operation.
    Any insights to this problem, welcome.
    Laurence
    #448284
    Re: Miele Auto W842 Rinse Light Flashing?
    page 5 simple pcb tips
    simple-pcb-repair-tips-t51155-45.html
    relay and fuse fault done a few. Also check shock absorbers as lots of bouncing can cause this fault
    laurenceuk
    Thanks, Dave. I’ll give it a go.
