miele d/w g638 plus
  • #18751
    eng14
    hi all went to this m/m today,its got a warning light flashing on facia,inlet/drain problem.both these checked no problems,will do some programmes perfect then on others it aborts with same light flashin.ideas thanks richard.
    #180247
    Seamy
    Re: miele d/w g638 plus
    Check base of machine.for water. Perhaps float switch has been activated? If no water in base check that float (polysterene) is seated correctly. Inlet/drain is the same led on these from memory, faults i’ve come across are something stuck in non-return valve or inlet (waterproof system) fault. The non-return valve is accessable from inside dishwasher, below filter, take off clip & look for something fouling impellor of of drain pump.
    Hope this helps
    #180248
    fidder
    possible that rubber on drain pump expanding and causing pump to run slow or stick…if not comletly drained in one min…will go to fault…Trev
