miele d/w g7859
  • #55929
    dealdd
    got a call to this commercial d/w. coming up with f26. has anyone got error code list or service manual for this
    #325638
    washermanuk
    Re: miele d/w g7859
    Fault code F 26 Water present in drip tray.
    No water present in drip tray. On machines with a steam condenser and if the seal between the steam condenser and cabinet is defective, condensate can flow down the rear panel, along the underside of the cabinet to the sump. Here the water can cause an occasional short circuit at the float switch contacts leading to fault code F 26 being registered. Traces of such a water flow can only be seen after particularly close examination.
