miele d/washer g611 – 5 flashes
Home Forums Trade Technical & Spare Parts Forums Trade Technical Enquiries miele d/washer g611 – 5 flashes
  • #50193
    Minge
    Hey!!
    this dishwasher starts flashing the inlet/outlet light 5 times after a minute of filluing and pulse fills. Any ideas please? There was evidence of water leaking from small air hole in side tank. I replaced this as i had one.
    :rolls: ❓
    #303921
    washermanuk
    Re: miele d/washer g611 – 5 flashes
    Before rectifying the
    problem you must:
    – Turn the programme
    selector to the “Stop”
    position.
    – Switch the dishwasher
    off using the “On/Off”
    button.
    Water intake is restricted. – Open the stopcock
    fully.
    – Check the water inlet
    filter and clean if
    necessary, see
    “Cleaning the water
    inlet filter”.
    – Check the water level
    and if necessary
    increase the water
    intake time, see
    sections on these.
    Water outlet is restricted.
    Water remains in the
    wash cabinet at the end
    of a programme.
    – Clean the filter
    combination, see
    “Cleaning and Care”.
    – Clean the drain pump,
    see “Cleaning the
    drain pump and nonreturn
    valve”.
    – Clean the non-return
    valve, see “Cleaning
    the drain pump and
    non-return valve”.
    – Remove any kink in the
    drain hose.
    Problem solving guide?
    hope this helps? Brian
