Miele D/Washer G646SC Leak – See Photo, Insight Wanted
Home Forums Trade Technical & Spare Parts Forums Trade Technical Enquiries Miele D/Washer G646SC Leak – See Photo, Insight Wanted
  • #90511
    laurenceuk
    Just after a little insight in case someone has experience in this regard.
    The Miele is leaking into the base. I took the bottom cover off and chocked the machine up a couple of inches.
    On operating the leak appeared almost immediately and dripped off the bottom of the motor – see picture.
    The underside is pristine and when I inspected the area again having laid it on its side there was no evidence of any water anywhere else (that was observable) other than the where it had dripped from the motor.
    I am presuming the impeller housing seal has failed. I am looking for a little reassurance as anything to do with Miele can be expensive. :eeek:
    Can anyone confirm this can be a weak area?
    Many thanks.
    Laurence
    #445053
    boselecta
    Re: Miele D/Washer G646SC Leak – See Photo, Insight Wanted
    Hi Lawrence,
    Yes fitted a few motor seal kits.
    The seal kit can be bought separately from the motor, as far as I know you can only purchase it directly from miele.
    #445054
    laurenceuk
    Thanks Boselectra, appreciate your feedback.
    I found this at at connect. Is it correct?
    https://connections.connect-distributio … id=1654372
    Thanks again.
    Laurence
