miele disdhwasher
  • #51756
    loopey
    Hi guys
    miele turbothermic G579SC dishwasher
    It wont heat up on wash or dry but goes through ok. checked stats pressure switches , heater ok . circ pump has alot of pressure behind it
    is there some thing i am missing , checked harness at front door ?
    thanks in advance phil
    #309191
    gandh1
    Re: miele disdhwasher
    as a service measure also check the air tube for the turbo fan they get gunked up nicely, if u dont clear it anyway, sods law dictates it will happen straight after you leave anyway.
    its been a bit of time since the last time i did one so memory was hazy, iirc tho if the turbo fan window didnt open it wouldnt actuate the drying, once the tube was cleared it worked perfectly and that was about 3 years ago
    #309192
    loopey
    ok cheers for that will check it out 🙂
    #309193
    washermanuk
    worth checking heater relay matey
    #309194
    loopey
    😳 dunno what ive done but its working ok now lol . did have a look at the wire matrix on the right hand side .. ? tightend up all the connectors …:)
