Miele dishwasher
  • #102553
    SWERV
    I try to stay clear of Miele dishwashers, but I have agreed to look at this one as a favour.
    It’s showing error code F14 which I believe is something to do with the pressure switch? I don’t have the model number yet, but are their any tips/tricks that can help before I attend.
    Merv
    #489392
    switch is mounted on the side of the motor. to access bottom of the unit has to be removed which means getting towels to mop up the water
    this fault could also be low pressure on motor output so you would need to check pump input. Bad news is on most of them the pump is against the rear wall so the sump needs to be removed
    if its a really late on with the 3 phase motor be carefull as the pcb feeds 300VDC to the motor and the circuit has high voltage caps
    SWERV
    Thanks for the info Dave.
    #489394
    neon_3SP_glow
    Whenever a miele DW goes wrong, I instantly think… plastic wrappers in the wash motor, seen it so many times. Blocks the impeller blades and causes heater switch believe the machine is dry of water.
    Just a thought.
    #489395
    SWERV
    Thanks, I visited yesterday.
    The customer said that they had tried it several times and it would always display F14 after 3-4 minutes. I ran it before I pulled it out (it’s integrated) and it filled to the correct level and then started washing. It was running for approximately 10 minutes and then it tripped the circuit breaker, which it did twice. I meggered the heater which was ok and I then removed the connections to the heater relay and then the earth fault cleared. There was also moisture around the terminals of the heater relay, although I couldn’t see where it was coming from.
    #489396
    are you talking the heater relay or the pressure switch on the motor pump housing
    had quite a few pressure switches fail and blow trips when rubber diaphragm fails
    SWERV
    Sorry, yes I meant the pressure switch on the motor housing.
    Merv
    #489398
    yes it will be that switch had a few of them fail its not uncommon
    if you disconnect the switch and meter from the terminal to earth you will get a reading when it should be no reading at all
    also Miele parts are usually cheaper if bought direct from miele
    https://www.miele.co.uk/c/spare-parts-and-accessories-24.htm
    click on “visit spare parts catalog”
    SWERV
    Thanks Dave.
