Miele dishwasher Home › Forums › Trade Technical & Spare Parts Forums › Trade Technical Enquiries › Miele dishwasher This topic has 9 replies, 4 voices, and was last updated 11 months, 4 weeks ago by suedehead1. Viewing 10 posts - 1 through 10 (of 10 total) Author Posts April 11, 2025 at 6:32 am #103298 suedehead1Participant model G5500SC fills up sprays for 10 minutes then says CHECK INLET no leaks no blockages any ideas welcomed April 11, 2025 at 7:40 pm #492551 electrofixModerator is it losing water or is it still trying to fill ? Dave April 12, 2025 at 1:21 pm #492552 suedehead1Participant its not loosing water or trying to fill it just aborts after washing for 10 minutes April 12, 2025 at 4:13 pm #492553 electrofixModerator ok few things spring to mind is the wash motor overheating and shutting down ? if you switch off at the wall and wait 10 secs or so , what happens when you switch back on ( a lot of units start where the programme stopped ) you could try pausing the programme for 10 mins, if it lets you , or open the door. was trying to find out if something is getting too hot Dave April 13, 2025 at 11:48 am #492554 suedehead1Participant ok thanks for the advice I will go and take another look April 14, 2025 at 4:58 am #492555 KentishParticipant I would check for debris in the wash motor impeller. or possible flow meter April 22, 2025 at 10:37 am #492556 neon_3SP_glowParticipant plastic wrappers in pump impeller or heat pressure switch faulty… If wash pump doesn’t generate enough pressure (or if heat pressure switch is faulty) check inlet shows, as logically it thinks it hasn’t filled. April 22, 2025 at 10:38 am #492557 neon_3SP_glowParticipant * Wash motor impeller April 27, 2025 at 11:02 am #492558 suedehead1Participant thanks very much April 27, 2025 at 1:07 pm #492559 electrofixModerator there may be something in here that may give a clue https://www.manualslib.com/manual/1333124/Miele-G-4205.html#product-G{e5d1b7155a01ef1f3b9c9968eaba33524ee81600d00d4be2b4d93ac2e58cec2d}205{e5d1b7155a01ef1f3b9c9968eaba33524ee81600d00d4be2b4d93ac2e58cec2d}20Series Dave Author Posts Viewing 10 posts - 1 through 10 (of 10 total) You must be logged in to reply to this topic. Log In Username: Password: Keep me signed in Log In
