Re: miele dishwasher fill/drain light on
Sounds like a low water pressure fault, machine starts after certain time has elapsed & if not enough water is in to activate level switch when circulation pump is started you get a fault.
Worth checking why its slow to fill, perhaps filter in inlet pipe is dirty.
If its got a waterproof type solenoid fitting on end of hose, you can take out the water restrictor with long nose pliers, ( its like a small black washer ).
Time can be extended by going into service mode but check fill problem first.
