Machine not heating water or drying at end of cycle.Apparently intermittent.3 lights illuminated.
Sometimes works ok,but becoming more frequently no heat fault
Heater element checked out ok & heated fine when I tested it.
Suspect pcb?
not sure of this model but the ones I have seen have a pressure switch on the motor that detects pressure to stop heater operating if motor not running. If this fails or not enough pressure result no heat
