MIELE DISHWASHER G1182SCVI
  • #63165
    larry
    PLease can anyone help,This dishwasher fills very slowly until it seems to time out and the Fill/Drain light flashes and the beeper starts,i tried filling it partly with a bowl of water but stills just keeps filling the same until the light flashes and beeper sounds ive cleaned out the filling matrix . ❓
    #352820
    Seamy
    Re: MIELE DISHWASHER G1182SCVI
    Was there a flow meter ( little p.c.b ) mounted on the matrix? They are prone to sticking. If it’s counting pulse/litres of water via a flowmeter filling with a bowl would not activate it & you’d still have problem. Other problem to look for is circulation pump stuck & not running, which should activate pressure switch after water has filled to correct level.
    #352821
    larry
    will the flow meter pcb have to be replaced
    #352822
    Seamy
    Not always, sometimes they are not seated correctly & the wheel/counter does’nt turn & hence the magnet doesn’t operate reed switch. Careful, they’re quite delicate !
