Went to this machine today. After selecting a program and pressing start the machine drains starts to take in water for a second or two then stops and the check drain check inlet flashes. I have checked the filter at the inlet valve, and a good water pressure from the plumbing supply. I have a good ohms reading at the water valve. I have checked the wiring loom for any breaks in the door. The voltage to the water valve cuts out after a second or two. Is there anything I have missed as I suspect the control module. Any replies are much appreciated.
Not sure if it is meant to be open or closed circuit to be honest.
Try putting a magnet near it if it switches you know it is ok.
It’s usually the wheel that spins in the matrix which the reed switch counts that sticks.
Checked the reed switch continuity which was OK. I also jumped out the level switch which is in the circuit but same fault. It looks like the control module as I don’t think there is anything else in the circuit for water intake valve. I have tried a new reed switch.
