This dishwasher when switched on and a program selected, start button pressed, drain pump operates for a few seconds, stops and starts again and does drain the machine. The drain pump stops and the inlet valve operates for a second then the wash rinse light and the start light go out. The inlet drain light then flashes. There is no water in the bottom of the machine and the drain pump works well. I have tested the inlet valve and connected a fly lead to it to ensure there’s no problem with water intake. Any pointers on this would be much appreciated, I have two of these machines in my workshop with the same fault!!!!!!!!!!!!!!! 😕
Is the wash motor impellor clear? I can’t remember all the model numbers that I have to deal with or their fault sequence but have seen it many times where the wash impellor is semi blocked with detergent wrappers or the like and the inlet light flashes after a very short while.
