Miele Dishwasher G665SC-2
  • #18930
    kevinlewis
    Inspected and found loads of salts ect around the seal of the main motor causing a short to earth. Removed motor to workshop, dried it out and have cleared the earth fault. Great, but the long term leak has caused the alloy to look pretty tired. I separated the pump from the motor and believe that I can get away with just replacing the water seal.The seal is similar looking to the Bosch seal. Is the seal available for this machine?
    Is this a feasable repair, ” i’m trying to be green”, or am I asking for problems?
    Any idea on the cheapest place to buy a new motor from as i know connect are never the cheapest supplier. Any second hand motor out there?Price of new motor from Connect is £212 plus vat.
    Nr 20/17815603 about 5 year old
    Number on motor 97341209 mpe31-62/2
    #180923
    Seamy
    Re: Miele Dishwasher G665SC-2
    Motor (complete unit) listed for that machine is Part Num’ 4998104 @ £187.40 +v.a.t off Miele
    The pump section is available as a separate, Part num’ 5100732 @£43.66,
    but i believe the seal you need is @ the motor bearing?
    correct me if i’m wrong, seal where pump pushes onto sump of machine is also available
    hope this helps
    #180924
    fidder
    Re: SEAL FOR Miele Dishwasher G665SC-2
    THE SEAL ON THIS PUMP IS A CERAMIC AND RUBBER SEAL….JUST REPLACE IT…ITS EASY AND A GOOD REPAIR…
    REGARDS TREV FROM ANGLESEY…WORKED FOR MIELE AS ENGINEER.
    #180925
    kevinlewis
    yes it is the ceramic/rubber seal on the motor shaft. It looks similar to a bosch seal but do Miele sell the correct one and do you know the part number? thanks.
    #180926
    fidder
    DONT KNOW PRT NO…BUT YES THEY DID SELL THIS PART SEPERATLY WHEN i WORKED FOR THEM.
    #180927
    kevinlewis
    tried fitting the similar Bosch seal but found slight sign of water. Also motor going to earth again due to the dampness which is making me think that the insulation on the windings has been damaged due to long term effect of the detergent and salts that have built up on the alloy and windings.
    I’m still in the market for a second hand motor or finding the genuine Miele seal as customer wont spend over £200 on a new motor.
    #180928
    fidder
    give me no of pump…trev
    #180929
    ALL Miele components have a T.no printed, moulded, engraved, stuck on them – this is the part number.
    fidder
    What is the Tn No. on plate please?
    #180931
    kevinlewis
    TEIL. 4493460 IS THE NUMBER ON THE PLATE IT ALSO HAS 79341209. TYP MPE31-62/2. THE PUMP HOUSING HAS PPGF30
    #180932
    Dave_Conway
    Although the seal is shown on the diagram you can’t order it seperately (according to the diagram anyway), it comes with the pump housing – part number 5011732 😉
    #180933
    kevinlewis
    been in contact with Miele who e mailed me the picture of the motor ect. although the motor is split up into different parts only the complete motor is available part number 5000814 at £175plus vat. I then spoke to someone in the technical department who said that the pump housing is available part number 5011732. I feel sure that the seal in quesion is available, Bosch and Siemens have a similar seal, but where to find it?
