What are the letters after model number? Have you actually seen it? Which led’s are on? Does it allow you to set programme and if so how long will it run before stopping? Check simple things first like, no water in base operating float switch. Heater element is ok, water is on at valve etc . Had heter relays go on these but not much else. I’ve never had one go crazy like this.
As with most dishwashers it attempts to pump out water firstly, perhaps it isn’t getting the water out & theres a fault coming up? Have you looked in the sump where the pump inpellor is located?
See the non return valve at pump, open this & look for obstruction.
If you are not getting anywhere ring Miele & ask for technical dept’ they are usaually quite helpful.
Have same fault as yourself, all lights flashing, did you find problem? Bruce. Miele G679SC-VI-2. WATER FOUND IN BASE, but cannot reset module, maybe a PC need to reset as port to plug in avaiable to upgrade software?
