Miele Dishwasher G686SC
  • #34756
    roly16
    This machine fills, circulates for a few minutes then stops and indicates an inlet/outlet fault. When the programme is re-started it pumps out ok. Is this a control unit fault or is there something else I should be looking for?
    Geoff
    #243894
    Re: Miele Dishwasher G686SC
    could be the high pressure pressure stat, clips onto the circ pump. either blocked or faulty. If the timer doesnt recieve a signal from it within a few seconds of the pump starting up. it aborts.
    #243895
    Seamy
    Could be as simple as inlet filter on water pipe blocked, or flow meter problem.
    Most likely the level switch not getting enough pressure of water, this can because machine did not fill with enough water to bring on pressure switch or that there is an obstruction in the circulation pump.
    #243896
    fidder
    will be the leakproof system…tilt the machine sideways and see if water comes out from tray area…Fidder
    #243897
    Dont know, he does say it runs for a few minutes before failing so would discount the leak theory.
    #243898
    roly16
    If you re-start the programme after it’s gone into fault mode, exactly the same thing happens; it pumps out, re-fills , runs for two or three minutes and locks out again. So it doesn’t sound like water in the base, as I assume it wouldn’t re-fill in that situation. The customer has had Miele or a Miele agent round who has diagnosed it elecronically as a pcb fault but I’m not totally convinced. He didn’t open it up to test or inspect any internal components.
    #243899
    Seamy
    Roly he shouldn’t have to open it up!
    Most Miele engineers should be competant enough to enter service mode & see fault codes which should help in pinpointing cause of failure.
    One of these would say “float switch activated” if theres water in base, if you get my jist.
