Miele dishwasher g858
  • #5229
    Scotty
    can anyone help, the bottom of the three spray arms is not working, cannot find any blockage,and the other 2 are fine. 😳
    #110011
    Dave_Conway
    Re: Miele dishwasher g858
    Scotty,
    I phoned our local Miele agent today to order a few parts and asked them about this while on the phone. They need more info, apparently there are 10 versions of G858, there should be something else after it, like plus, or similar. They think there may be a solenoid or water directing device that alternates the water supply between the upper and lower spray arms, probably stuck in the “upper” position.
    If you let me know the rest of the model number, I’ll try and find out a bit more for you.
    #110012
    Scotty
    Thanks dave. The numbers i have are g858scu1plus ser num 26/63749552 😛
    #110013
    Dave_Conway
    I just spoke to them again, during the conversation I cheekily asked if Miele would supply a parts/info cd.
    They do ! And it’s only about £17 😯
    Anyway I ordered one which should be here in the next couple of days, so I’ll be able to have a better look then.
    #110014
    Just a thought Scotty, its not set on a half load programme is it?
    oh and Dave, Ill have one of them discs if you get any spare.
    Mark.
    #110015
    Scotty
    I thaught the half load setting was a possibility initially, but it does not seem to be the answer. I would not rule anything out. ❗
    #110016
    Dave_Conway
    The dishwasher does definitley have what is called a “circulation valve” part number is 5268861. It may not be that of course but it must be the obvious choice if the half load option has been eliminated.
    #110017
    Scotty
    Hi Dave
    Is this circulation valve a water valve or some kind of solonoid
    scott 💡
    #110018
    Dave_Conway
    It’s hard to tell really Scotty, the drawing isn’t that clear and the desription is as I desribed above.
    Probably both I would imagine, a valve that is controlled by a solenoid 😕
    #110019
    The AEG circulation valve uses an AKO timer type motor to regulate their “distributor valve”. Perhaps a variation on the theme?
    JAT,
    Penguin.
    #110020
    Seamy
    Off the top of my head, Miele dishwashers have a “Top Solo Function” this is similar to 1/2 load, a solenoid near the circulation pump is used to allow or prevent water going to the lower spray arm, this sticks sometimes with debris grease etc, from memory i’ve never had to replace any, just had to remove & spray with wd40 etc to clean & put back in place, hope this is helpful.
    Seamy
    #110021
    Scotty
    Dave are their any test progs or fault finding charts on the disk
    Scott
    #110022
    Dave_Conway
    Scotty wrote:Dave are their any test progs or fault finding charts on the disk
    Scott
    Sadly no. It’s just a parts identification disk, there is however a technical support telephone number on the paperwork that came with it to activate the disk, it may be worth a try, it’s 01235 233141
