Miele dishwasher G977 Plus inlet/drain flashing
Home Forums Trade Technical & Spare Parts Forums Trade Technical Enquiries Miele dishwasher G977 Plus inlet/drain flashing
  • #52793
    Islander
    Machine starts to fill then stops after few seconds, then inlet/drain light starts to flash. It keeps filling like this but doesn’t start to wash. There is a flow meter on the side chamber which appears to be turning ok. I have also checked the inlet filters and water pressure seems to be ok. Customer has recently had some plumbing work done so the stop cock was turned off could this have affected the machine?
    #313141
    Galway
    Re: Miele dishwasher G977 Plus inlet/drain flashing
    not sure if this will help but had a similar problem with a different model and it turned out to be the water level indicator /which is a kind of pressure switch.but it could also be something in the impellor of the main wash motor.
    #313142
    Seamy
    If water supply has been ajusted its maybe that its not filling to required level in time. Common problems with them are faulty flowmeters or connections from flow meter to board.
