Miele Dishwasher HELP please!!
Home Forums Public Support Forums Help And Support Dishwasher Help Forum Miele Dishwasher HELP please!!
  • #27012
    luckyme38
    I have been quoted £98.00 for a callout to my Miele dishwasher. I have been informed that there are only a couple of Miele qualified repairers in the UK as this make rarely break down.
    The model is a G676SC. Have been through the troubleshooting guide but this makes no difference.
    The problem is that all the lights flash on and off. The only program that will run is the pre-wash. STRANGE!!
    Can anybody help re the cost of callout and whether it is worth paying for an expert on the Miele brand, and can anybody shed any light on what the problem is with the dishwasher,
    Many thanks
    #212288
    marcowash
    Re: Miele Dishwasher HELP please!!
    Hello. To detect the problem in your Miele dishwasher is follow the instructions:
    1-make sure the door is closed and the programme selector is on the Stop position
    2-Push and maintan pushed the Top solo button while you switch on the machine. maintain the Top solo button pressed for a second then release it and quickly push it two times. The led “on” will light and the “wash” and “dry” leds will blink. if this doesn’t happens then restart from point 1.
    3-Turn the programme selector clockwise to the first programme.
    4-Push Top solo button
    5-Turn the programme selector clockwise until the led Top solo lights up.
    If it blinks in the first position (F0) then you have no faults (which is not likely to be…)
    If it blinks in the second position (F1) You might have a problem with the NTC bulb (the sensor that measures water temperature) or its connections (connection opened).
    If it blinks in the third position (F2) The problem can be in NTC bulb shorted or shorted connections.
    If it blinks in the fourth position (F3) the pulse counter is wrong
    If it blinks in the fifth position (f4) you have a problem with the heating element and/or its connections
    If it blinks in the sixth position you have a problem connected with the water inlet or the heat element controlling pressure switch.
    If it blinks in the nineth position then you have a problem with the drain or with the above pressure switch.
    To clear the error you just have to set the programme selector to Stop and switch off the machine.
    I hope all this will help you!
    All the best
    Marco
    #212289
    marcowash
    Errata corrige… Please change the word “blinks” with the word “lights up” in all the fault list!
