miele dishwasher problem
  • #18212
    sandysuds
    hi can any one help? a miele dishwasher g638 plus,
    it comes on ,fills, sprays and turns for about 2minutes ,then stops and the inlet/drain light flashes
    #178145
    qas
    Re: miele dishwasher problem
    Most likely cause would be a faulty pressure switch – the one that is attached to the wash pump. If that hasn’t operated when the heater is due to come on the inlet/outlet light will flash.
    Other possibilities are low water level due to faulty inlet valve or low pressure.
    Original part number for pressure switch: 5419692
    Steve
    #178146
    fidder
    could be leakproof system…tip machine to one side..if water comes out of bottom…thats your problem….fidder
    #178147
    Did one similar on Sat, there was not enough pressure to operate the high pressure-pressure switch hence no heat. Stripped down the circ pump and found the blades of the impellor completely clogged with debris that was awkward to clean out. never seen anything like it before and one to watch out for in the future.
    #178148
    sandysuds
    Many Thank,s To everyone ,new pressure switch solved the problem in the end, Good to know there is help available.
