miele drain pump
  • #61268
    machineman
    model w820
    gen pump 3568614 £91
    can we get a non gen pump for one of these
    cheers guys
    Re: miele drain pump
    Masterpart do some pattern ones. I think ML51101 may fit but you’ll probably need to shift something around, possibly have to move the field coil 180 degrees. Or extend pump wiring to reach. Bit of a faff but it’s £20 not £90. Also, I’m not sure it has a toc. but it does have an earth terminal where the original doesn’t.
    Mike.
    #345500
    machineman
    Dont have an account with them. qualtex do one for the MIELE 300-400-600-800-900-1000 SERIES does that mean it will fit a w820
    cheers Dave
    #345501
    Best method is to compare pictures. Connect has reasonable pictures of the genuine from 2 angles. Otherwise try googling part number.
    Mike.
    #345502
    AMS
    ML51102 will fit. Genuine Miele alternative to 3568614(shaded pole) is 6239560(magnetic). Put that part number into Masterpart’s website and it comes up with ML51102. Still comes in at £59.38, but it’s still better than £91!
    Good luck,
