miele dryer t8302 wont heat??
Home Forums Trade Technical & Spare Parts Forums Trade Technical Enquiries miele dryer t8302 wont heat??
  • #80666
    deltra
    hi, this dryer wont heat up, element,brushes etc are ok, anyone know the values of the ntc on element, or got a manual(have tried it with wet washing 😉 )
    #413675
    clayside
    Re: miele dryer t8302 wont heat??
    Would check pcb relay board, mounted top right under lid
    #413676
    deltra
    Thanks, never tried repairing relays,always sent boards to Qer/emw, maybe I’ll give it a go save a few quid 😀 only thing is ,how to test them 😕
    #413677
    if its got 3 rectangular relays then its the old style board, can be repaired but have to butcher the old relays off due to double sided soldering. newer- replacement board has 4 square white relays and is far more reliable. Getting on for £100 IIRC. Its the contact that go so no easy test other than check for voltage at the board about 90 secs after the programme starts. You may even hear the relays click which is a sure sign. (use the timed warm air drying setting to be sure)
    #413678
    deltra
    Ok ,thanks
