MIELE DW TURNING ON & OFF
Home Forums Public Support Forums Help And Support Dishwasher Help Forum MIELE DW TURNING ON & OFF
  • #99705
    ANDY NOSTOCK
    i have a miele g4920 sc dishwasher which has started turning its power on & off numerous times during a wash cycle. I have checked the filters in the machine & there are no blockages or debris & everything moving as it should. I have also had the back off & checked the pump impeller & hoses & again all seems ok. My only conclusion is that the synchronous motor is on its way out & needs replacing. At £62 i don’t want to buy it & find out that it’s not the reason for the fault. If anyone can suggest whether they agree with my diagnosis or come up with another cause for the fault i would be grateful. Thanks in advance. Andy
    #477489
    when you say turning power off please explain more
    just the motor or all the lights on the control panel as well ?
    ANDY NOSTOCK
    Hi Dave. It is a complete shutdown of power. All the lights go off. Everything will then come back on with no intervention, the wash will continue & then shut back down again periodically.
    #477491
    have you tried another socket ?
    ANDY NOSTOCK
    No but its a valid point. I will give it a try. Thanks
